Pull carbs, look at the valve and OH MY GOD!!
Old Apr 24, 2008 | 09:42 AM
njdjh2o's Avatar
Default Pull carbs, look at the valve and OH MY GOD!!
When I pulled the carbs off to give them a cleaning (which didn't need to be done), looked down the as saw so much carbon build up on the valves. I know this isn't good and need to be clean, how do I go about doing so.
I can only see the intake valve and if those are dirty so is the exhaust, I read a post about Seafoam, which I use in my cars. But, with so much on them, will Seafoam work?
Old Apr 24, 2008 | 09:47 AM
SilverF3's Avatar
Default RE: Pull carbs, look at the valve and OH MY GOD!!
Will that build up make a bike not start up or run?
Old Apr 24, 2008 | 10:44 AM
CBR13F2's Avatar
i would spray them with carb cleaner. saturate those valves with the stuff. let it soak a bit. then you can burn it off. i would change the oil just in case ANY seeped by your piston rings.
Old Apr 24, 2008 | 12:46 PM
njdjh2o's Avatar
No, for the answer of bike not starting., try messing with the idle **** on the side of the bike by the fuel ****.
I can get the intake valve but not the exhaust valves. Seem like I be investing in Seafoam.
Old Apr 24, 2008 | 01:31 PM
kwong2001's Avatar
Pull your headers and you'll get the exhaust valves.
Old Apr 24, 2008 | 02:12 PM
njdjh2o's Avatar
Well, that will be my weekend chore. Plus, I need to pull the carbs again, when I re-installed everything I notice I didn't put one of the carbtube clamps on.
Cro
Jul 28, 2008 12:05 PM
Nimbus87
May 8, 2008 11:02 PM
Kingpat
Feb 19, 2007 02:36 PM
Kikepiz
Feb 9, 2007 06:46 PM
