panic!
ok, ill try this again. i have a 95 f3 with a starting problem. the issue is that it wont start right away. i have to have the choke fully on and jumping the battery. before i jump the battery the bike will crank strong until the battery dies, then i jump it. about 15-20min later of cranking the bike sputters a little, then starts. now heres where the issue is. once the bike is started i can ride it around all day but when i gun the throttle and the rpms come anywhere near 8grand it boggs and sputters then takes off like a batt out of hell. the other issue is once ive been riding it all day and shut it off, if i start it within 30 min it will start right up but any longer the whole problem repeats. im wondering if my jets are clogged? when i hit the jets with the air hose no fuel spits out the top, or maybe a coil issue?? i just bought new coils(i need to know what wires plug into which coil and where) just to make sure its right from previous owner. or could it be a fuel problem?? thanks
yes im sure its choking fully i watch the bar pull the 4 little tabs. ok ive got the brand new coils on what colored wires go where if ur sitting on the bike????? i need to know that asap!! this is extremely aggravating. im thinking its the carbs because of all the sand build up around the brass fittings(jets)
