omg. what happened?
omg. what happened?
okay, so i was doing the last bit of work on my bike before i start riding next week. all i did was check the contacts on my fuel pump. it was ticking away perfectly, so i decided to take it out for a spin. you cant look at your bike running in the driveway and not want to right?
so i get a couple of miles down the road and i see my temp gauge higher than normal. i quickly pulled over to check what was wrong and when i turned my bike off i heard a noise, it was my coolant reservoir bubbling like crazy, sounded like a witches cauldron on haloween with dry ice in it and it was leaking all over the place. it was the actual white reservoir, not the lid for the hoses (that would have exploded like a 2 liter bottle had i opened it while the bike was hot).
ive never experienced anything like this before, thus have no idea how to diagnose the issue. any insight would be much appreciated!
first thing i would check is thermostat.. does fan kick on? take off thermostat and try to put it backtogether without it idk if it needs it as a gasket but i would try it .check for kinks in hose maybe u kinked a hose while checking pump. remember to put more fluid dont over flow it.. thats what i would do but im a nooby to bikes!!!
Definitely take a look at the fan and the switch the kicks the fan on. The switch is a temperature sensor that sits on the left side of the radiator and works as a switched ground (-). I ended up hard wiring mine to a flip switch just because the original set up seemed unreliable in summer traffic.
Baxter,
you say you were a couple of miles down the road. Do you mean two or had you gone much further than that?
If you'd gone two miles then there's no way your engine temperature would have reached normal running temperature even if you have got a rather pleasant ambient temp.
The rapid engine temp suggests that your thermostat is stuck. The water bubbling out of your reserve tank suggests that it suddenly unstuck, or the relief valve vented the pressure in the cooling system out through the reserve tank.
Run the bike again after checking the coolant level (under the radiator cap, not the reserve tank) and if it happens again you've probably got a buggered thermostat.
If it doesn't happen again, happy riding. It may pay to clean out the thermostat housing at the very least.
i was just cruising around my neighborhood, never over 30mph. it was 81 degrees outside today. i actually noticed that the fan wasnt kicking on when the temp went above what it should have been. since its so noisy. so i should check my thermostat to make sure everything is okay and flush the coolant and then i will be good to go until this grumpy thing wants to strand me again?
Baxter,
Don't be tempted to run without a thermostat. The bikes are engineered to run at certain temperatures. Running without one would cause it to run way too cool most of the time, and that's not necessarily a good thing.
