Oil on my Plugs
RE: Oil on my Plugs
You don't have to replace the pistons. The cylinders would need to be honed and new rings put in, but unless there is something wrong with the pistons, you can reuse them. If there is cylinder damage, then maybe it would have to be bored, that would be expensive. A new used engine might be the better way at that time.
Have you done a compression test ? Is it blowing smoke ?
