Oil Filter Change
Old 12-02-2008, 01:10 PM
razonje's Avatar
Default Oil Filter Change
Ok so you are all probably going to laugh, but how do I get the oil filter off of my 97 F3? I cant get an oil filter wrench over it because it wont fit due to the itty bitty space betweenthe filterand the pipes. I am assumingI need a different oil filter wrench, right?
Old 12-02-2008, 01:17 PM
Ruthless's Avatar
Default RE: Oil Filter Change
You need the smaller wrench. It does fit.
Old 12-02-2008, 01:20 PM
Northernfirepower's Avatar
Have you tryed using your bare hand? Shouldnt ever be tighter than that. Worse case you can punch a screwdriver in the side of it to break it ... I had to do this on my F4i this spring from the last person over tightening it.[:@]
If you go this route, be very carefull and try to keep it to the end of the filter for the engine case has threads at least 2in deep into the filter.
Old 12-02-2008, 02:20 PM
Gunnar's Avatar
I use adjustable pliers to twist it off.
On another bike of mine there was even less room,
and I took an old leather belt around it.
Put the end through the buckle so that it would clinch down tighter as I twisted it.
"Poor man's oil filter wrench", I called it.
But it worked like a charm.
Also, when installing the new one, tighten by hand only.
Old 12-02-2008, 10:15 PM
ORIGINAL: Gunnar
that's a good idea. I used a standard car filterwrench and got it in there alright
Old 12-03-2008, 12:25 AM
pacemaker's Avatar
I've had the same one for years, its has an adjustable leather strap, works like a charm.
Old 12-03-2008, 12:38 PM
razonje's Avatar
Awesome tips everyone! I already filled the oil back up but I will change the filter next time now. Thanks!
Old 12-03-2008, 12:46 PM
TheX's Avatar
New oil and old filter? ewwww
Old 12-03-2008, 01:49 PM
sXe's Avatar
sXe
sXe is offline
ORIGINAL: razonje
ORIGINAL: TheX
That's like taking a shower and putting on the same dirty underwear.
Old 12-03-2008, 03:13 PM
pacemaker's Avatar
ORIGINAL: sXe
ORIGINAL: razonje
ORIGINAL: TheX
Yeah but its like you have turned them inside out 1st.
Quick Reply: Oil Filter Change
