Odometer problem
Old 07-14-2008, 09:32 AM
chiefF3's Avatar
Default Odometer problem
So my odometer is acting strange... it clicks off backwards! then it will go forward then backwards...if i knock on it it goes the correct way..... someone advise.
Old 07-14-2008, 10:09 AM
Northernfirepower's Avatar
Default RE: Odometer problem
Trip odometer or the actual?
Old 07-14-2008, 10:45 AM
chiefF3's Avatar
ORIGINAL: Northernfirepower
both for the most part. right now i think it might just be the trip[ counter but at one point it was both
Old 07-14-2008, 11:10 AM
SIRR1's Avatar
Hmmmmm thats strange.
Honda speedo's and trip meters rarley fail.
They may give anincorrect mph reading at speed but the units dont start clicking backwards unless someone has opened the speedo unit and messed with the units odometer.
That is the only thing I can think of unless the bike was crashed and had big time front end damage that effected the instrument cluster.
Next time you have the fairing off take a look at the back of the instrument cluster.
Each screw that holds the speedo unit together has a paint dot on the screws head.
If the paint dots don't match up with the back of the instrument cluster and the screw headsthen you know someone has tampered with bikes millage.
Old 07-14-2008, 11:17 AM
chiefF3's Avatar
ORIGINAL: SIRR1
i bought the cluster on ebay cause my speedo didnt work on my orginal cluster so that i dont have to worry about. i was just confused at the back and forth tracking
Old 07-14-2008, 12:57 PM
**** this forum is irritating!!!!
My trip button is in three peices and causes the broken parts to tamper with the reset. Take the cluster apart from the surround and see if you have the same issue.
Old 07-14-2008, 01:52 PM
redzintimidator's Avatar
mine was broken in 2 pieces after my lovely wreck...a little superglue and its back in business.
Old 07-14-2008, 02:08 PM
Hmmm, never though to repair the broken pcs. I swept them up with the rest of my mess yesterday too!!
Old 07-14-2008, 02:46 PM
chiefF3's Avatar
ORIGINAL: redzintimidator
when i press the trip reset it bends..so if its broke could that be the issue?
Old 07-14-2008, 03:26 PM
Yeip, it's hard to describe how it works. Just take the cluster apart and you'll see how the lever can mess with the reset if not placed properly
Quick Reply: Odometer problem
