No gas at choke
No gas at choke
I have one last issue i need cleared up.. I can start bike by spaying gas in carbs and after it warms up i can just tap the start button and it will fire up great. But next day when engine is.cold i have repeat to fire up again. I k ow my. Choke is not letting gas in becuase i crank it while watching choke gas outlet and. Nothing comes out. My question is what jets do i have to clean to clear this up. Thanks for the help. And im this close to getting ready to ride daily. With all yall help thanks!!!
Yes i have adjusted the idle cable, or do you mean idle screws (pilot) im about 2 turns out. I took out all choke needles and can get some carb spay through the starter jet , the non removeble one, but not alot. Could air tubes be clogged? When i bought it the guy had it running on choke but it was my first bike so i didnt have a clue. This was probable a problem he had but failed to tell me. What all make gas pump out of choke? Should i get some new carbs? This is my only issue on the bike that i need to get riding. If i start it with gas in carbs itll start up all day. Thanks for the help!!!
