Newbie looking for some help!!!!
Old Feb 15, 2012 | 06:19 AM
csimkalo's Avatar
Default Newbie looking for some help!!!!
Hello all! I am new to the site. I am looking at buying a cbr soon , yay tax returns, and am generally leaning towards an f3 or an f4. I have been reading a bunch of posts concerning buying used bikes, and am not new to buying used vehicles. How ever I am not quite sure on what specific problem areas to look for on the f3. The bike I'm looking at has 32xxx mi and from what I've been "told" has been regularly maintained. Any specific things I should pay specific attention to? I e I have read the r/r is a common issue what should I look for to see if Its worn,going out or what not. Any help or advice would be greatly appreciated. Thanks
Old Feb 16, 2012 | 08:15 PM
Cr250r67's Avatar
If you are interested in this bike ask the owner about the cct, Manual or stock (you can tell by looking at it) as the stockers are prone to fail. And check the R/R by making sure the voltage at the battery is 14.5 or so at 5k rpm. I Always check wheel bearings, swing arm bearings, and steering stem bearings on any bike I buy. If the bike has a rattling sound around low rpms its most likely the cct and very easy to replace. If you have any specific questions about the bike you are looking at this is the place to ask as these guys and gals are a wealth of knowledge. Below is a picture of a manual cct it is just behind the right side inspection panel
Here is a picture of a stock cct
Old Feb 16, 2012 | 08:17 PM
Cr250r67's Avatar
If you are interested in this bike ask the owner about the cct, Manual or stock (you can tell by looking at it) as the stockers are prone to fail. And check the R/R by making sure the voltage at the battery is 14.5 or so at 5k rpm. I Always check wheel bearings, swing arm bearings, and steering stem bearings on any bike I buy. If the bike has a rattling sound around low rpms its most likely the cct and very easy to replace.(if it is stock and does not rattle it will soon) If you have any specific questions about the bike you are looking at this is the place to ask as these guys and gals are a wealth of knowledge. Below is a picture of a manual cct it is just behind the right side inspection panel
arcotc
Jan 13, 2021 02:45 PM
Kook87
Mar 15, 2012 05:24 PM
SilverShadow
Nov 2, 2009 01:30 AM
coldbloodedlounge
Jun 1, 2007 04:43 PM
marbzcbr
Nov 27, 2005 06:13 PM
