New member
Old Apr 16, 2020 | 08:45 PM
blazen244's Avatar
Default New member
Hey guys I need a bit of help my wife has a Smokin Joe version of this bike and the carbs are toast I need to know if any of you guys could direct me to who or were I might locate a good set thanks in advance?
Old Apr 17, 2020 | 01:20 AM
chris0986's Avatar
I cannot imagine carburators are so much toast that some cleaning and new seals wouldn't do the job.
Ultrasonic baths do 99% of the job, so buying new ones would be a bit excessive.
Especially because I think they are very expensive...
And almost every garage can clean carburators or tell you who can
Old Apr 17, 2020 | 09:21 AM
What exactly is wrong with them?
Old Apr 17, 2020 | 12:22 PM
blazen244's Avatar
Ok guys here it is the original carbs were left with seafoam in them for about three yes three years and it really gummed them up I purchased another set used and sent the bike to a friend that works well with older carb motors. Once installed I could get the bike to run but they aren't 100% a match so missing some vacuum ports on the carb body and once I connected it runs really crappy and no throttle response. The original ones since I was under the impression they weren't needed I took them a prt still have everything but can't find anyone who wants to take on rebuilding them because the jets were removed. I could have sent the carbs back but I didn't know they weren't a match until the warranty expired the never mechanic never said anything. Bonehead yes but I thought this would be an easy fix for him I should have just sent it to a local indy for the repairs.
Old Apr 17, 2020 | 01:25 PM
It's not the worst mistake anyones made. Don't sweat it.
why not take a shot at rebuilding the originals yourself?
It's not an insurmountable thing to do. It mainly takes patience as it's a tedious thing, a few special tools and the willingness to do it
There are a lot of videos to show you how and all the help here.
even if you bought a brand new OEM set out of the.box, they would still need to be sync'd.
Old Apr 19, 2020 | 11:28 AM
blazen244's Avatar
Is there a write up on this if so I'd try it I don't mind wrenching don't think I can make it worse.
Old Apr 19, 2020 | 11:38 AM
blazen244's Avatar
Just watched a video of guy syncing a set of carbs on an old Honda he says he removed the vacuum lines and capped them just curious how is that done? I will post a picture of them a bit later and if you guys will give me your opinion
Old Apr 19, 2020 | 12:44 PM
The ports are on the engine just below where your carb boots connect. Cylinder #1 has a small screw. 2-4 have a rubber plug.
Old Apr 19, 2020 | 12:52 PM
On YouTube there is a guy called mr max story.
he has all.kinds of great videos including carb cleaning and syncing. You might him to be helpful.
Old Apr 19, 2020 | 01:59 PM
blazen244's Avatar
From on side the butterflies are stuck closed
