Need help with gas leak
I'm having trouble separating the carbs to change the o-rings at the fuel pipe. At first I thought if I take out the two long bolts that go through the carbs, then carb 4 would come off the end. I haven't taken the bolts all the way out yet, but I have visions of springs flying everywhere. So my questions are..
Do I need to take those two bolts out all the way?
Do I have to separate carbs 1 & 2 from carbs 3 & 4 first?
What else do I have loosen to take off to get carbs 4 away from 3 and 1 away from 2?
Thanks in advance...
You have to take the carb rails out to split the carbs. No worries, there aren't any springs... there.
The springs that'll go flying are at the carb adjustment screws between carbs 1 & 2, 2 & 3 and 3 & 4. If you are gentle while pulling the carbs apart, they won't fly out. Locate them before you separate the carbs and note how they're installed.
You don't have to take the rail completely out of the carburetors. Taking the nut off the end is fine. Separating the carbs can be tough because the "O" rings are stiff and not lubricated. The aluminum spacers on the rail between carbs are precision fit and if the carb doesn't come straight off the rail, they will bind. I used a flat blade screwdriver to gently pry on one side of the carbs and then the other. Try working all of the "T" fittings between the carbs back and forth while you pull on the carbs. A little patience and they will come apart.
THANK YOU very much for the pictures in this thread IDoDirt.... they finially asnwered my question on what parts to order... those parts fiche that are easily found all over the internet are confusing when it comes to this... even my local stealership was confused and would have got me the wrong thing if i would have trusted them
