My Wrecked Bike
RE: My Wrecked Bike
Wow rear tire slid out huh? Sux bro....the tire looks pretty good, were u by any chance leaned over pretty far and accelerating pretty hard, or was the street wet or what? Just curious to know exactly how it happened since Im usually concerned with my front tire sliding...
Yeah part it out on eBay, will make the most $$ out of it....good luck.
RE: My Wrecked Bike
Thanks man, I loosened the triple clamps and straightened the forks out, no problem.
Does anyone know if the top of the fork tube can be replaced? Mine is leaking out the top...the bolt broke off and the threads are messed up.
[IMG]local://upfiles/9998/06315CB6995E43C899B53525F7B2423B.jpg[/IMG]
RE: My Wrecked Bike
Well I replaced the stator cover and the timing chain? cover and filled it up with oil to see if it would run and it does. I think i'm going to fix it, paint it, and sell it.
Most of the damage is cosmetic. Only two major problems remain..
1.) The top of the fork tube is broken off and oil leaks out (see my previous post)
2.) The bike wants to turn/lean to the right.
I'm thinking that maybe the triple clamp can be adjusted to fix the turning/leaning problem. Can someone verify this?
RE: My Wrecked Bike
Your rim could be bent, mine did the same thing it wanted to turn more towards the right, when I turned left it felt like it was wanting to pull right......took it to the shop and my rear rim was bent........My right handle bar is slightly turned right also....I might try to loosen the tirple clamp and see if it fixes it....Mine was wrecked before I bought it and I just fixed it for less then $500 buying parts on ebay.....but mine wasnt wrecked as hard as that.
