my F3 project bike
picked up this bike for 600 bucks(and another 600 in shipping from texas to ohio lol) 10,000 miles, titled, it has been laid down before, and was ridden by a guy until he went in the marines for a year. he said that when he got back it wouldnt start. turns over and acts like it wants to start but wont. i guess he said he anda friend rebuilt the carbs and it still didnt. here are some pics. please dont bash me too hard, it was 600 after all and needs some workhttp://img3.freeimagehosting.net/uploads/f74a22fb76.jpghttp://img3.freeimagehosting.net/uploads/d1c20a5426.jpg
RE: my F3 project bike
oh by the way its a 96 cbr600 f3
there can be many different things wrong with the bike, both mechanical and electrical. depending on how long it's been since the carbs were last cleaned, you may want to just have them cleaned again.
going forward, i'm pretty sure you've tried putting in a new battery (if not, you'ed better try that before anything else) so my advice would be to do the following: 1. check the fuse box and make sure all the regular fuses are good 2. check to make sure all the connectors of all the wires are secured. 3. check the main starter relay (check the fuse... it's a 30amp located on the relay; the relay is near the fuel pump) i. take a wire and connect the two terminals on the main starter relay to test whether or not it is faulty 3. make sure you are using new gas... bad/old gas can prevent your motor from running. start with those and see what happens. good luck! |
it looks to be in pretty good shape...you'll probably end up spending a G in parts for it to looks like an f3 again., but if you are looking to flip it I can see you pulling 3 out of it with a clear title...good investment and good luck!
[align=left] [/align] |
did you change the spark plugs? when i first bought my bike, the same thing happened...it sounded like it wanted to start, but never did, i changed the plugs and she fired right up!
i didnt yet. hes sending me the keys right now so im gonna do that when i get them
where are the spark plugs at on this bike and how many are there? ive never done this before
go to stephygee.com and download the owners manual there, it should be on the bottom left of her page...there are 4 spark plugs total, they're kinda a bitch to take out and change...if you look at the first picture you posted, the spark plugs are underneath the red covers underneath the gas tank
Looking at the pictures it looks asthough the rear end has had some welding done to it, might want to check the welds to make sure they are done right.
If you look on the top of the engine you will spot the HT leads which will lead you to the spark plugs, there are 4, I can see from you pictures that you are missing the tool kit which is a shame because they make it really easy to get the plugs out. It looks like its had some money spent on it in the past, with the exhaust, steering damper, and crash sliders |
