Milky Oil Help.
So i just got my bike back outta the shop.... had the carbs the cleaned and what not. got the bike last summer and never changed the oil well i get it back and runs like a TOP! then i noticed a little bit of a rattle on the top end of my motor, it will do it then stop then do it then stop so i said well maybe the oil is old and what not. drained the oil and looked kinda discolored and milky. Bike has never ran hot. wondering if anyone could help me.
Ticking at the top of the motor is usually valves of lifters. How many miles are on your bike? Are you SURE there's enough oil in there? Are you doing wheelies \ 12-o-clocks? You'll need to overfill your oil if that's the case.
Can you describe the oil more? Color, consistency, smell? Was it sparkly liek metal-flecked paint?
oils a dark brownish color. got some dark color variations in it. checked the radiator fluid and its full. resivor is also full. to me it kinda smells like gas. but i do remember i tryed to do a do it yourself carb cleaning job and had 20oz of gas come up missing and dont know where that went. could it be gas? and my bike has also been sitting uncranked until yesterday for maybe 5 months. could that have anything to do with it?
When the crankcase oil turns very light brown, about the color of milky coffee you're probably looking at a blown head gasket or a cracked head. The light color comes from the coolant leaking into the crankcase and diluting the oil ( you'll see foam until the oil cools). Result is diminished lubrication . Don't drive!!!. Also you'll experience overheating as the coolant moves from the cooling system into the crankcase. Solution.... remove head, examine head gasket ( you'll be able to see blow-by from the water jacket into an oil hole, if the gasket looks normal... replace, then take the head to auto machine shop and have it magnifluxed. They'll be able to tell you if it can be repaired or you can simply buy a used head on ebay. Don't forget to adjust valves if you swap heads. PS This is what happens after a severe overheating session. The longer the operation while"hot" the worse the damage. Good luck!
take a metal rod or a stick or something and try to pinpoint where the noise is coming from....i know i just took apart a set of heads cuz i thought it woul be a broken valve spring...turns out it just needed valves shimmed...jap bikes are bulletproof and generally last forever as long as they are half way taken care of....it may just be that youre being over critical
