Lowering cbrf3
Hello all.. new to this forum. I have a Cbr600F3 1997 and I am wanting to lower the bike a little cause I just think it doesnt look right cause it sits to high. I am looking for a lowering link asuming that what I need. I am pretty sure I know how to lower it, but I would like someone if possible to help me out and give me some back up info on how to lower it? What tools I need and how? How do I lower the front? would you recommend the lowering? thanks for your help
Well I bought it cause I got it for 800 dollars fully rebuilt new everything, The guy I bought it from though the motor was blown but I knew it was the reg/rec or the stator so I bought it. I like how it looks I just want to drop it a little to make it look better. I like the way dropped bikes feel when they are ridin. No I dont have a problem with height, I am 6'1 so My feet are planted on the ground. I just want to lower it a little. Oh yea and possibly stretch it just a little. This is going to be more of a show bike for me, everyone is going to kill me here, but i have a R1 for daily driving purposes. any advice would be great.
IMHO I wouldn't lower it. Honda did more research than one can imagine. The engine is at a certain degree, the tires are a certain distance apart, and the height........well you get my point. Although if your going for a show bike then I can see your reasoning. It's a fairly simple task though. You'll need to get your bike up in the air on a lift or stand. When I was doing my rebuild I just took off the fairings and used an engine lift (a.k.a. cherry picker). Once you have the bike up and tire off it's kind of self explanatory if you ask me. Unless you have no mechanical skills what so ever.Live and learn!
Good luck!
Good luck!
Point made... I see where you're coming from and going.
For lowering you need a replacement link in the rear and just slide the fork tubes up in the front. For supporting the bike, stop by Home Depot or Lowes and pick up some 3/8" or 5/16" steel bar. It comes in 3' lengths. The F3's were designed to have a center stand installed on them (look at the parts manual). The steel bracket is already mounted to the frame for this stand. It has holes in it about 1/2" (you can measure if you like to be sure) in diameter. Take the fairings off and you can raise the bike up on a floorjack (have someone hold the bike steady so it doesn't fall during this process) under that bracket.
Slide the steel bar through the holes where the pivot pin for the center stand would go and support each end of the shaft on Jack Stands. Put the Jack Stands as close to the bike as you can for the best support and balance. Now you can work on the swing arm with the bike supported really well. I used this method to remove my wifes swingarm to get it powder coated. Reverse the process to take it back down.
