Low Compression Issues
I just got a 97 CBR 600 F3 from a guy in South Houston. He told me there was a problem with low compression in one of the cylinders. Other than that he said it was perfect. He had the fuel lines disconnected but the bike sat for a few years and the tank had gas in it and rusted up and turpentine collected in the tank. I cleaned the tank with Muriatic Acid, rinsed, dried with M.E.K., and applied Red-Kote (is this the correct way to do this? I did a lot of research beforehand). Back to the cylinders, I got it checked out by a mechanic and this is the information on the test along with his notes and comments:
Cylinder compression: 1)52 psi 2)54 psi 3)53 psi 4)56 psi
Notes: engine needs piston rings. Valves not seating on cylinder 1.
Leak down test: cylinder 1)bad 2-4)good.
How much is this going to cost to fix and what exactly do these notes mean? I understand what they are saying for the most part but im not sure exactly where to start and what rings, gaskets, valves and parts I will need. Any help would be greatly appreciated.
Do you have any recommendations on where would be the best place to get a used motor? Im in a town of about 8000 people so Id have to have it shipped here. Yes I do know someone that works on bikes. My roommate is pretty experienced and will be helping me with the work. If I understand what youre saying, I'd just be better off getting a whole new engine instead of trying to get the individual parts to repair the one i have?
Well if you're not going to a stealership, DIY would be cheapest... But the most aggravating. Getting a new engine would be less measuring, unbolting, tinkering and cursing the Honda gods. But more expensive than DIY.
I would recommend getting a new engine too.. but if your in an adventurous mood and want go the DIY route, do it right and get a rebuild kit. There isn't much sense in tearing the whole block apart just to have a re-used bearing or seal fail soon after and put your back to square one. You can usually get an engine on eBay for cheap, most of the ones that I've seen are from motorcycle shops that also provide you with all the info on the bike it came from.
