Loud click when using front brakes
Since iv owned my CBR iv always had a loud click as the front brake engages, even after fitting new tapered head bearings...
I also noticed my callipers have a lot of movement after being torqued up, I figured they are floatings calipers and the click is just them jolting forwards when the pads grab the discs??
Thanks!
Thanks!
Check both sides. If one side is loose the other might be getting close to being that way.
Where the disc actually bolts to the wheel is perfectly fine and torqued up, its the actual floating half of the disc that moves, the outer ring! Not the actual rotor! I have read up on it and apparently its not much of a problem
g9s5r
Jul 24, 2009 07:36 AM
adambowersva
Jun 30, 2009 05:09 PM
