Loud click when using front brakes
Old Apr 20, 2014 | 08:35 AM
Joecbr's Avatar
Post Loud click when using front brakes
Since iv owned my CBR iv always had a loud click as the front brake engages, even after fitting new tapered head bearings...
I also noticed my callipers have a lot of movement after being torqued up, I figured they are floatings calipers and the click is just them jolting forwards when the pads grab the discs??
Thanks!
Old Apr 21, 2014 | 08:11 AM
Joecbr's Avatar
Think iv found the culprit, if I grab my discs and pull them back and forth one moves and click and the other is sturdy, should I replace the one with movement or will it be fine??
Old Apr 21, 2014 | 09:13 AM
74demon's Avatar
Any problem with the brakes is unsafe. Fix it before you ride another inch.
Is the movement where it bolts to the wheel? Loose or incorrect bolts?
Old Apr 21, 2014 | 11:24 AM
RoadiJeff's Avatar
Senior Member & Lord of The Man Cave
Find what the torque value is supposed to be on the attachment bolts, stick a torque wrench on each bolt and tighten them in a crisscross pattern. It sounds like one disc is loose.
Check both sides. If one side is loose the other might be getting close to being that way.
Old Apr 22, 2014 | 04:44 AM
Joecbr's Avatar
Where the disc actually bolts to the wheel is perfectly fine and torqued up, its the actual floating half of the disc that moves, the outer ring! Not the actual rotor! I have read up on it and apparently its not much of a problem
Old Apr 22, 2014 | 05:55 AM
74demon's Avatar
Replace the rotors. You should not be able to movve it there by hand.
shok47
Oct 15, 2010 09:04 AM
STREETFIGHTER88
Mar 2, 2010 08:15 AM
g9s5r
Jul 24, 2009 07:36 AM
adambowersva
Jun 30, 2009 05:09 PM
bd2002F4i
Apr 6, 2009 10:15 AM
