Lost here
Ok i have a 97 cbr f3 and just replaced the stator and dont know why it will run in the back yard for a hour no problems but once i take it around the block all power goes away please some one help
OK, provide some history here. Why did you replace the stator? Describe in more detail what you mean by "all power goes away". Does the bike go completely dead? All the gauge cluster lights go out? All power like has no performance?
i replaced the stator cause i thougth my battery wasnt charging.and when i say all the power engine dies lights gone like its sitting there parked in a garage
When it dies, what things do you do, look at, or try in order to get it running again? Are you able to, or what do you have to do in order to get it running again? Have you been able to get it running again?
That has all the makings of a lose connection. A total loss of power like that would certainly seem to be electrical. I'd be looking at the connections on the Start Relay. There is a 4 pin connector on it. Verify the connections are good an snug. The connection to the Ignition Switch (key switch) is a 3 pin connection, check it as well. Power flows from the battery, to the Start Relay, on to the Ignition Switch, then over to the Fuse Box on the right upper cowl before being distributed to the rest of the bike. Do you have a shop manual? That would have the wiring diagram so you can follow the wires.
So here was the issue it was my fault but hey now im going to fix the problem thanks for all the tips they all help even though was not the issue ive cleaned up my wiring checking the things you suggested again thanks
