looking for the redbull mod walkthrough
Old 08-23-2010, 05:40 PM
Craig84's Avatar
Default looking for the redbull mod walkthrough
recently went to spencers and got a sonic the hedgehog energy drink and thought to myself this is way better and not like anything anyone else has, but trying to search the forms i cant find the walkthrough for it, i know its pretty simple, cut and strap but i was curious if theres anything more to it?
fast responses would be great cause i wanted to do it asap
Old 08-23-2010, 05:44 PM
andyriot's Avatar
Nothing more. First cut out as close to the edges as possible. Then cut slit down the back. Then measure it up to your shock canister and mark/eye a good length. Cut one side. Make sure it looks good. Cut other side. Not too much, cut less than you think if youre worried. You can always trim it a bit more. You will also need to cut some off the width as well because it will more than likely overlap itself. Once you have the can ready, simply unscrew the clamp and slide your can in, then tighten.
Old 08-23-2010, 05:52 PM
Craig84's Avatar
so instead of just cutting the top and bottom and slipping it on, ill probably need to cut down the side and overlap it?
Old 08-23-2010, 05:56 PM
andyriot's Avatar
Well im guessing the can is larger in diameter than your shock res (as are most cans). What I did was cut a slit down the back of the can and then trim a bit from each side (width) until it met evenly in the back when wrapped around the shock res.
it just takes some patience and some trimming/measuring. I also added a little line of electrical tape to the back once done so the sharp edges werent so exposed
96CBRJimmy's Avatar
yea, you'll have to cut a small strip off the can since the damper is a smaller diameter than the can.
Old 08-23-2010, 05:59 PM
Craig84's Avatar
I really appreciate the fast respose, I'm gonna go do it and post a pic up shortly
Old 08-23-2010, 06:00 PM
andyriot's Avatar
I just happened to see it right after you posted it. Good luck, and remember... measure twice cut once! Show us how it turns out.
Old 08-23-2010, 06:38 PM
Craig84's Avatar
it was a little fustraighting cause the label was really cheap lol but it looks ok i think, its also to bad soinic isnt running down the side of the can thatd look way cooler
i dont like how small that pic is so heres a bigger view
Old 08-24-2010, 10:57 AM
bammerman's Avatar
That is pretty cool looking
Old 08-24-2010, 03:14 PM
wheelmn's Avatar
I took the hose clamp off mine and used a zip tie instead. But I used a beer can cause I am Canadaian!
Quick Reply: looking for the redbull mod walkthrough
