A little help?
So I recently picked up a local racers 'spare' F3... or so he says it is an F3.
Since joining this forum and looking around I have learned that I have an F2 front rim. Problem is, I have no idea what the fork is for sure. He told me that it has Race Tech Gold valves. Is there any way to tell which fork it is without taking it apart to see if its cartridge or dampening rod? What is the difference in the front axle between F2 and F3?
Also, I figured out looking at BikeBandit, I have determined that I have an F2 airbox, and have already found a complete F3 airbox and air ram assembly.
Are there any other big differences that I need to be aware of or can I treat it like an F3 from here on out?
On top of the forks, do you have a slot for a flathead screw driver? If you don't you have F2 forks. The only way to know for sure if it has a race tech gold valves is to take the forks apart. Which I would do anyways so that you know what the valve is set at compared to your weight and riding ability. Any pictures you can take I can help you some more.
Ill take pictures when I have some more time, probably Friday afternoon. I honestly can't recall what they even look like... I just got everything home and stashed it in the back of my garage behind my other 8 bikes hoping my wife would'nt see ANOTHER bike project. I could have sworn it had the adjusters you mention... but ever since discovering that I have an F2 front wheel I doubt everything about this bike.
First Honda, I am a Suzuki boy... I would be able to tell in a second if something was mismatched on a GSXR.
Is the F2 radiator flat and the F3 curved?
I know that Honda likes to put a GIANT label with the model year on the right side of the steering head, but it is missing so I have no obvious clue what year it really is.
there used to be a website that when you typed in your vin number, it would tell you what year, where it was produced, what color it was, etc.
this isnt the one i remember, but it will do the same thing.
http://www.decodethis.com/Home/tabid/36/Default.aspx
So it turns out that I may have gotten taken for a ride. Either that, or the guy really had no idea what he had in the first place...
His 97 frame/engine has an F2 front end and radiator... So he could have just been that oblivous.
I have decided to make it into an F2/3 with the F3 radiator, airbox, and bodywork, add a fuel pump...
If it's got gold valves and springs in it though, shouldn't matter since that pretty much replaces all of the internals anyway.
