Light knock at idle
ORIGINAL: FoxRacin17
i think mine does that too. what exactly do you mean by a knocking sound? i use the high stuff at the gas station. 93?
it needs 87 octane only!!
read the damn manual, you are throwing money away and losing horsepower!
Found this and thought it was intesting, it seems to think that higher octane fuels prevent pinking.
Knock" and its relative, "Detonation", occur in the engine's combustion chamber under conditions of extreme heat and compression, and a weak mixture or low-octane fuel. During the engine's compression stroke, the pressure of the air / fuel mixture is raised, which increases its temperature. This is good, because it makes it easier to ignite. However, when the pressure and temperature get too extreme "detonation" or "knock" can occur.
Detonation occurs when the spark plugs fire and the flame burns too quickly, resulting in the air / fuel mixture detonating, rather than a controlled burn. Also known as "pinking".
"Knock" occurs when the air / fuel mixture has its temperature and pressure raised to the point where it spontaneously ignites in the combustion chamber without the aid of a spark.
Knock is the phenomenon you're most likely to hear about. Both these problems can result in severe engine damage if allowed to occur unchecked, and both can be helped by using a fuel with a higher octane rating, as it will be more stable, and less susceptible to spontaneously ignition. Contrary to what a lot of people seem to think, a higher octane fuel does not necessarily equate to greater engine performance - rather, it allows the engine to run at hotter temperatures and greater compression ratios. This can allow an engine to generate more power in a given period of time, thereby yielding greater performance.
[blockquote]quote:
[/blockquote]
bro you bike does not need anywhere NEAR that high of octane.
[/blockquote]
its a bike it will make noises from time to time unless you are hearing some loud knockin that other ppl notice worry, if not just ride .and no nothings wrong with puttin high octane gas in the f3 the manual says 90 n above ,but you can use regular which you wont see any difference .
