Led lights issues
Old Jul 16, 2019 | 02:26 PM
Face310309's Avatar
Default Led lights issues
Hello, I have tried installing led lights to my 95 cbr600f and the rear ones work but the front ones don't..... I checked the leds work and they do but when connected to bike..... Nothing, the bulb lights still work when connected but not the new leds.... I changed the flasher relay to led one after the leds just stayed on without flashing...... So currently have bulb lights on front and leds on back and they all work in this configuration .... Any ideas people?
Old Jul 17, 2019 | 09:38 AM
TimBucTwo's Avatar
LED's are polarity sensitive. Check you wiring to confirm ground is ground and hot is hot.
If the rears are working, I would suspect a polarity problem up front.
Old Jul 18, 2019 | 03:56 AM
Face310309's Avatar
Did a swap of wires and they now flashing properly, thank you so much..... Only issue I have now is that only 6 of the 12 leds in each light are flashing, don't suppose you know why..... The lights have built in resistors and I have an led relay. Reason for both is I thought the led lights with resistors would work as the seller said they would..... And they didn't so got the relay and now at the point described above?
Old Jul 18, 2019 | 04:07 AM
Face310309's Avatar
I just had a thought if only half the leds are working due to resistor and relay, would some led lights without resistors work fine, please?
Once again thank you ever so much for your help with this I am very grateful and will ride around with half lighting ones till issue sorted.... At least all 4 are the same now
Face310309
Jul 16, 2019 02:25 PM
rustynail17
May 8, 2012 12:28 PM
bwyellowjacket
Aug 27, 2008 06:59 PM
andrewsi
May 12, 2008 09:43 PM
KidCr3nshaw
Apr 1, 2008 04:18 PM
