LED install help
Old Feb 24, 2010 | 03:24 PM
EffThreeFyrBall's Avatar
Default LED install help
I tried a search but was unable to get a definitive answer to my issue. I am installing new LED front blinkers on my 97 F3 and they only have 2 wires. I have gathered that the green wire is ground. My issue is I am not sure which wire is the blinker and which is the running light. There is a solid wire (blue/orange) and a striped one on each side. Which one is the blinker wire?
Old Feb 24, 2010 | 04:05 PM
ajzcamaro's Avatar
On my 95 it was as follows:
Green = Ground
Solid Orange = Blinker
Orange with White stripe = Running Light
Plug up the light and before final install make sure to turn the key on and check to see if you have a running light or just a blinker. With the the solid orange and solid green you should only have a blinker. If this doesn't help I can get you a picture b/c I'm about to pull the fairings on my bike.
Old Feb 24, 2010 | 04:23 PM
right on, I'll try to check on it tonight or in the morning and let you know. Thanks
Old Feb 25, 2010 | 11:21 AM
much thanks AJ that is exactly what I needed. Now my fancy new LEDs are up and running. Thanks again
Old Feb 25, 2010 | 02:30 PM
Willkster's Avatar
Post a pic of these new and improved led blinkers! I am thinking of doing the same thing. Let me know where you bought your as well so i can maybe rip your idea off! Thanks a lot!
Old Feb 26, 2010 | 04:10 PM
the bike is going to paint in a few weeks once I finish getting the body put together lol. I needed to fill the original blinker holes then drill a new hole for the post on the new ones. They look pretty nice and are plenty bright. Once I get some pics of them on I'll post 'em.
BPWilson_F3
How-To: Mechanical
31
Aug 18, 2013 06:55 PM
Sick97SS
How-To: Mechanical
Aug 21, 2010 09:51 PM
agleam0fhope
Apr 29, 2009 12:53 PM
DerekS
Mar 27, 2008 11:51 PM
FoxRacin17
Dec 21, 2007 02:25 PM
