idle adjuster was tampered with
RE: idle adjuster was tampered with
what do you mean by messed around with?? Are you talking about the **** on the left side by your thigh, or the choke? cuz the **** will keep it from idling if you turned it too far out, it might have come unscrewed at the carb.. you'll have to pull the tank and look...... but.. if you hold the throttle open a bit, it should start and run.. just wont idle if you let go....
