How to reduce cruising RPM a bit?
Old 10-16-2011, 11:42 PM
HenryM's Avatar
And I should have read the first post properly.
Sorry for dragging you off piste.
I wonder if it's possible to install a secondary gearbox? Just a thought.
Old 10-16-2011, 11:44 PM
HenryM's Avatar
Originally Posted by jeffjones
I know mine isn't the same as Will's but I have an F4i with stock gearing and I am at 88mph @ 7k. So he isn't far off from me?
110+mph @ 7k sounds a bit low?
So when your cruising down the highway at 60mph your under 4krpm's?
That doesn't sound right?
60 MPH is 3900 RPM on my old beast.
I'll have to check again what 7K RPM equates to. I think it may be more than 110 MPH come to think about it.
Old 10-17-2011, 05:41 AM
Will.Bass's Avatar
Originally Posted by HenryM
Will,
at 7K RPM I'm traveling at around 110+ MPH. My gearing is stock.
Your gearing sounds completely out of whack. Check the Honda manual to see what your model should be running, front and rear sprockets. 84MPH at 7K is very low gearing, wheelie heaven, if that's what you're into.
the gearing the PO had put on my bike is +1 +2 over stock. Which makes that 84 at 7k better than what most people on here are getting with their f3's at 7k. (most are from what ive seen mid to high 70's.) are you talking about an f3? and are you talking in MPH or KPM's. because i stated 84MPH
readings on your speedo you may want to think about fitting a speedo healer
Your speedo will be clocking up many more miles than it should if you leave your set up like this.
in my first and only post on this thread i stated how i that i already have a speedo healer...
Old 10-17-2011, 09:52 AM
jeffjones's Avatar
What is the redline on your bike?
Old 10-17-2011, 05:26 PM
HenryM's Avatar
Blimey, so many questions.
I'll set my stall out properly.
I have a 1991 1KF-L. She's an old beast but spritely. I ride every day.
This evening I verified my comments earlier about speed at 7K RPM and yes, it's 113-115 on the speedo. Stock gearing remember.
Given that NV is running a Frankenstein he may have a cart wheel for a back sprocket and not be able to go any smaller for whatever clearance reason.
Why though, are all you guys with newer F4i's and the like telling me you're getting around 85 MPH (in top gear I hope) at 7K RPM?
My red line is 12K and the engine will go there very readily.
Is the F4i red line that much higher that Honda have opted to lower the gear ratio that much.
Let's clear this up, it's bugging me now.
Old 10-17-2011, 06:20 PM
coalminer frank's Avatar
You can only go so big on the front sprocket before clearance becomes an issue. You could try a taller rear tire. In theroy it would lower your RPM at any given speed. If you go with a taller rear tire, do some calculations and make sure its taller. Example would be 160/60 and 170/60. The height is 60% of the first number. So the 170/60 is taller than the 160/60. Hope that helps.
Old 10-17-2011, 09:11 PM
Will.Bass's Avatar
just above 13k on the f3 gauges. just above 14k on the f4i gauges. dont know any of the other ones..
Old 10-18-2011, 07:08 AM
jeffjones's Avatar
This evening I verified my comments earlier about speed at 7K RPM and yes, it's 113-115 on the speedo. Stock gearing remember.Why though, are all you guys with newer F4i's and the like telling me you're getting around 85 MPH (in top gear I hope) at 7K RPM?
The Redline on the F4i is 14k.
And in top gear about every 1k rpms = 20km/hr
I know at 140km/hr I'm @ 7k.
So I guess you bike can't get anywhere near redline in top gear?
Because if it did redline your bike would be doing 197mph?
Old 10-18-2011, 03:35 PM
HenryM's Avatar
Probably about right Jeff.
She's pulled a shade under 170 and at that speed I wasn't looking at the rev counter.
5th gear she'll pull up to 11.5K no sweat and that's a hang on for dear life job.
In 4th I've strayed pst the end of the rev counter.
When we were out riding the other day she managed 105 in second gear and the revs were about on the limit.
Unscientific I know but interesting comparison, old vs new.
A decent F4i would put me to bed so I'm not bragging, just enjoying.
Old 10-18-2011, 05:07 PM
jeffjones's Avatar
It's all good I was just interested.
But thats good to know, I always like the comparisons of bikes
bobbobobbo
07-22-2012 10:18 PM
redmason89
09-22-2011 03:11 AM
redmason89
09-22-2011 12:23 AM
Dragondima
06-04-2011 01:03 AM
birdmanta
08-18-2005 02:41 PM
Quick Reply: How to reduce cruising RPM a bit?
