How much brake fluid?
Old 05-03-2009, 11:39 AM
jpanside@gmail.com's Avatar
Default How much brake fluid?
Does anyone know how much brake fluid I need to fill the rear brake?
Also how much do I need to kill the front brake.
thanks!
Old 05-03-2009, 06:00 PM
pacemaker's Avatar
Non of the manuals actually state the amount you need. It all depends on how much fluid needs to be bled through the hoses to get rid of the air bubbles & if your starting from scratch, how much fluid is needed to fill the hoses as well as the reservoirs.
I always buy a couple of bottles just to do one brake (just in case) plus I use a bit in the bleed bottle as well.
Old 05-03-2009, 07:09 PM
f3BikeR's Avatar
The standard size brake fluid bottle of 'Prestone DOT 4 Synthetic' at Walmart is $2.68 and will do 2-3 changes of both front+rear
Old 05-03-2009, 09:39 PM
thanks bros!
johnnyx
08-22-2012 01:15 PM
CJardine
07-24-2012 09:41 AM
ThisisMickey
08-24-2007 03:38 PM
tutman6
08-27-2006 01:23 PM
hondacbr1000
07-22-2006 06:41 PM
Quick Reply: How much brake fluid?
