HOUSTON: My bike broke down
Ok guys something very weird just happened and I dont know where to start.
I turned my bike on yesterday let it wrm up, turned it off, covered it.
Today I was going for a ride, turn it on, fine no problems, but right before I leave I decided to check ho wmuch gas i had...so I turned it off and did just that. When I went to turn it on it had no intentions of turning on...then a loud pop with a fireball came out of exhaust and that was the last sound it made.
I havent started to test anything, but where should I start?
THe RPM gauge is completely still...it doesnt flicker at all when I try to start.
Has anyone ever had this happen to them? BTW the bike was running 100% before.
HELP![&o]
HELP![&o]
RE: HOUSTON: My bike broke down
You do more harm by idling your bike to, "warm it up," than you would by letting it sit there. You may have had moisture build up in the carbs causing it to backfire.
I'm not sure about using Heet on bikes, and if so how much - but I would start by making sure the gas is free of excessive moisture.
What does thumbing the starter do exactly? Does it crank and just not start, or does it not even crank? May sound stoopid but...
Make sure the kill switch is in the, "run" position. Make sure you are in neutral, if you're in gear, you've got to put the sidestand up.
Make sure everything is set, then thumb the starter and tell me what it's doing (cranking or not). Could have fouled your plugs as well. How many miles on the bike? Have you ever changed the plugs on it and if so, when?
You mentioned something strange:
" THe RPM gauge is completely still...it doesnt flicker at all when I try to start."
This makes me think that it might be an electrical problem or something with you're CDI. The ref counter should atleast show something when you turn the engine.
OK this is exactly what it does when I try to start her: All I know is that the starter is definitely turning, the battery is fully charged. But it doesnt sputter at all not even a tiny bit. Like if it had abosolutely no spark and no gas.
And then also is the RPM needle is just buried still...doesnt even shiver a tiny bit. Bike has 23K. THe plugs are new not even 3K, keep throwing ideas please. I wont get to play with it for a few days, but I just want to make a list of things to tackle. THanks in advance!
The ref counter is dead which tells that your CDI isn't on or isn't.This should atleast move if you turn the engine (even if it's flooded or not getting gas) working properly because the RPMs pulses come directly from the CDI.
I'd start by checking if the bike starts when you put it in neutral. If it does it's probably you're sidestand switch.
If that doesn't work check all the other switches related to this part of the wiring. If I remember correctly those include the sidestand switch, neutral switch and the switch on the clutch and of course the run switch.(Try and get you're self a manual or a wiring diagram)
CDI stand for cacpcitivie disharge ignition heres a link to one on ebay http://cgi.ebay.com/ebaymotors/HONDA...spagenameZWDVW
