-   CBR 600F3 (https://cbrforum.com/forum/cbr-600f3-17/)
-   -   HID problems (https://cbrforum.com/forum/cbr-600f3-17/hid-problems-146624/)
cmartino88 May 8, 2013 01:11 PM
Thanls, will let you know. Would you know how to go about testing my regulator/rectifier? I've searched the forums up and down and cant find anything on how to do it.
nvanvlymen May 9, 2013 08:11 AM
Ask and you shall receive. This would be a good starter guide, I remember seeing a better one around though.
https://cbrforum.com/forum/f2-tech-9...testing-91252/
Fobwareagle May 13, 2013 10:22 AM
How to Test a CBR Regulator Rectifier | eHow this is for an f4 r/r but they're prolly the same r/r so it might help...
cmartino88 May 13, 2013 10:54 AM
Thank s guys! Just an update, the weather around here has been absolute crap so I havent been able to run any tests. I'm hoping late this week will warm up a bit and I will post my findings asap.
cmartino88 May 14, 2013 01:19 PM
I have a friend running the tests for me at work, should have an update later. If I do end up scrapping the project does anybody know where I could find a reasonably priced headlight? Their are none on eBay right now, the dealer wants $200 which is ridiculous, and nobody is responding to my wanted ad. I honestly would only need the lens and not even the whole housing.
nvanvlymen May 14, 2013 03:01 PM
hope it works out. There should be a reasonable answer to the issue you're having. What your experiencing may only cause you problems in the future if you don't figure it out now.
cmartino88 May 17, 2013 07:10 PM
I believe I found the problem, I hooked up a multimeter to the headlight socket and it's getting surges of 16-17 volts when the headlight cuts out.
cmartino88 May 18, 2013 11:07 AM
I need a temporary quick fix for the issue, I was wondering If I can wire in a cheap 12V Inline regulator to the headlight wires until I can buy a new R/R. The specs on the radioshack regulator says it kicks on from 13.6V-17volts and produces a stable 12v current which sounds like it would be perfect for now.
nvanvlymen May 21, 2013 10:09 AM
Maybe, I don't think your going to do any additional damage that the R/R isn't already potentially doing by adding the regulator in there.
cmartino88 May 21, 2013 05:51 PM
Apparently the inline regulator wasn't in stock, it would take the same amount of time to get here as ordering a new one. I went aftermarket (because of the better cooling) with direct OEM fit. Should be here later this week.
