Help with my f3!
What's up yall. I need some help. I just bought a CBR f3 1995 and it's my first bike so I'm a newbie at this but as I was getting to know my bike I was fiddling with a **** next the to fuel supply valve and idiotically twisted it til it came off! I believe its the idle adjust? How do you put this thing back on and adjust it back to specs. CAN ANYONE HELP THIS NEWBIE!
real easy first get some locktite blue or red and put it on the screw and screw it in. then adjust the the idle,clockwise gives it higher idle counter gives it less, adjust it about 2 full turns clockwise and start the bike obviously if the bike is cold put the choke on. if it seems to be idling high above 4000rpm you may want to kick it down a bit maybe 3500 if it is possible. though this is not a good way to determine your idle but rather a way of getting your biked warmed up so you can set your idle. when your bike is warmed up, needle being roughly 1/3 of the way up set your idle around 1200rpm to 1300rpm and you should be good to go. hopes this helps.
OEM F3 Repair Manual
WinZip Extractor
WinZip Extractor
ORIGINAL: CBRider206
Its the whole cable with the springs and everything. if you have a picture where this is suppose to go that would really help. I thank you for all your help. I have a Clymer manual and it doesnt tell me nothing.
