Help my baby wont start!
Old 07-09-2010 | 11:10 PM
F3BANGER's Avatar
twice yes, the last time no
its a 1995 f3 with about 28000
Old 07-10-2010 | 07:39 PM
F3BANGER's Avatar
replaced the spark plugs cleaned what i could with the carbs, checked the filters and fuel pump. still nothing the engine just refuses to turn over. real bummer man anyone have any other suggestions before i drop money i dont have on a real mechanic?
Old 07-26-2010 | 12:42 AM
F3BANGER's Avatar
so i know its been some time, my bike has been in line at the shop and they finally looked at it. apparently its my fuel pump, but heres the thing i think their trying to screw me cause they want 200 to order the pump and another 500 to put it in. now ive seen the pump, its right by the reserve tank switch, why would they want 500 to do something so simple? am i missing something?? when i asked the guy he started talk about how its a 3.5 hour job and involves taking the airbox and carbs out. lol waT?
Old 07-26-2010 | 10:18 AM
NAP2AZ's Avatar
I had similar issuses recently but when I purchased the bike it had no pump on it. I got a used pump from a member her for like $30. I got some help identifying the hoses and bam hour or so later she was back up and running. Check out my thread called "fuel pump ??" has pictures. Most deff run with a fuel pump. That's why mine went down because of The prolonged use with no pump. Hope this helps!
Old 07-26-2010 | 10:22 AM
NAP2AZ's Avatar
And from my own experience I will never take it to the "shop" again. If I can't figure it out it's going to the dealership!
Old 07-26-2010 | 02:51 PM
dcaldwell's Avatar
i dont want to seem overbearing but just in case you forgot, i said this earlier, if it is your fuel pump it might be your contacts. if it is you can replace them for about 40 bucks. here's the thread, shows what bad ones look like, tells you where to get them and how to replace them. real nice write up from IDoDirt
https://cbrforum.com/forum/showthread.php?t=102151
just somethin else to consider before you drop that kind of cash
good luck and keep us posted
Old 07-30-2010 | 10:49 PM
F3BANGER's Avatar
so i got it running again but now there seams to be gas leaking out of one of these channels coming out of the carbs. they have no hoses attached to them. wtf are they and what do i do to stop it?
Old 07-30-2010 | 11:25 PM
nitrodude's Avatar
Those are your float bowl drains/overflows.
Take a screwdriver and make sure each one of the screws, right by each of those holes, are closed. It could also be that floats are sticking and the bowls are over flowing with fuel and draining out those. Not sure if the f3's do in fact have the "overflow" in there carbs, If they dont then one of those screws are just lose, and you need to tighten it.
Old 07-31-2010 | 01:46 AM
F3BANGER's Avatar
thanks! your the man!!
Old 07-31-2010 | 02:08 AM
nitrodude's Avatar
No problem, Glad i could help!
Quick Reply: Help my baby wont start!
