Help me choose race f3 bodywork
I've fitted 08 blade fairings to mine. I had to cut the ends of the front fairing bracket and weld them back on slightly shorter. I also had to move the radiator up a little and back a fair bit.
For the side mounts I just bent up some steel strip, drilled it both ends and bolted it to the side engine mount plates, then just twisted them till the holes lined up with the fairing.
The back mounts were easy, just bent and drilled aluminium strip. Left one off the kickstand bolt, using the original mounting point in the fairing. The right side i fibre-glassed in some 0.9mm aluminium plate in then drilled a new hole.
I also had to trim up the inside of the fairing where it hit the radiator and grind down the feet on the sump on the right side to try and get it as far back and high as i wanted.
lots of pictures here:
CBR 600 F2 Thunderbike
Thanks for the info. When I was going over your pictures I didn't see the radiator fan. Are you not going to have one or not put it on yet?
