Help with the house routes
Old 06-28-2018, 09:07 PM
gamekiller7's Avatar
Also my clutch cable is a little off when I engage the clutch I feel it's not engaging enough. Is that adjustment made at the handle bar or at the case?
  #42
Old 06-28-2018, 10:01 PM
If it is minor, then at the lever. If it is major, down at the case.
A tiny amount of free playbis ok.
  #43
Old 06-29-2018, 01:40 PM
When I pull the lever in all the way it seems to not be as much as it should.
Any thoughts on where I can order one carb boots strap? The piece to tighten the boot down to the block or carb. Bike was missing only one when I got it.
  #44
Old 06-29-2018, 04:06 PM
i know that you can buy them individually off od cheapcycleparts.com or maybe eBay
  #45
Old 07-02-2018, 04:32 AM
Do you know what size the carb boots are? 50mm? Thinking I'm just going to buy a radiator hose clamp and call it a day. Mainly because I have access to free ones at work. I also hate waiting for parts from eBay lol.
Bike ATM is waiting on new clutch and brake shortys and for me decide what fairings imI going to go with.
I've got 19 days till rebel road/bike time here and really want to ride this thing there. So hopefully within a little over two weeks I can get the levers on boot strap and bopefhope mount some fairings.
  #46
Old 07-02-2018, 07:33 AM
I honestly don't know in that one. I would try a 1.5" and then move up to a 2" if that doesn't work.
  #47
Old 07-03-2018, 06:33 AM
Hey I've noticed my forks don't decompress like they should. They're kind of hard to push down and don't pop back up.
I've never had to work on the forks before is this something like a fluid change or is there something more going on?
  #48
Old 07-03-2018, 06:41 AM
It is more than likely 1 of 2 things. They may be adjusted for a stiffer ride, which you can also adjust back. Or someone may have installed stiffer springs. If that is the case you would need to get ones suitable for your weight and replace them.
  #49
Old 07-03-2018, 07:39 AM
Hmm okay I'll see if I can adjust them. Never messed with forks before so if I have to pull them apart it wouldn't be the end of the world, I like learning new things about the stuff I drive and ride.
I'm assuming seals and springs can all be done by hand in my garage?
  #50
Old 07-03-2018, 08:05 AM
I'm guessing these are the adjustments for the front end?
Quick Reply: Help with the house routes
