HELP
Old 05-08-2008 | 01:18 PM
nrecore0223's Avatar
Default HELP
Ok here is the issue. In first gear only between 10 and 15 mph, i get like 1 or 2 clicking sounds that sound like they are coming from the rear tire. My chain is good and my rear tire is new. Its not a constant clicking. It just does it 1 or 2 times and then goes away. Its not there in any other gears or at any other speeds. I was thinking wheel bearings but i was wondering if that would be a constant noise. Any help would be appreciated
Old 05-08-2008 | 03:38 PM
SilverF3's Avatar
Default RE: HELP
Maybe its like one or two links ****ed Up on ur chain. IDK just a guess tho.
Old 05-08-2008 | 08:19 PM
pacemaker's Avatar
Default RE: HELP
Check your chain for the right tension, sometimes if you have a couple of tight spots, adjusting it without taking those into consideration can cause that noise. Bearing noises are constant, but as you increase your speed you don't always hear them. Bearing noise can start that way (click....click), as the 1st of the bearings starts to go. Put it on the stand & do a bit of detective work.
