-   CBR 600F3 (https://cbrforum.com/forum/cbr-600f3-17/)
-   -   Headlight stays on high beam (https://cbrforum.com/forum/cbr-600f3-17/headlight-stays-high-beam-145663/)
cbr_rob Mar 29, 2013 10:37 AM
Hi,
I've had a problem with the headlight ever since I bought the bike: the low / high beam switch doesn't seem to work at all and as a result it's staying on high beam the entire time. Bulbs are fine.
I've taken a look at the light switch assy, slightly sanded the connections a bit but this doesn't seem to be making any difference.
Am I right for suspecting the light switch assy? Or is there anything else that anyone would recommend?
Any tips much appreciated! :)
ryantgustafson Mar 31, 2013 09:35 PM
It sounds like the switch. Go at it with a multi meter and that will tell you whether it is working or not. Easy way to diagnose it. God luck!
cbr_rob Apr 1, 2013 10:03 AM
True. I guess I was hoping there was a quick (and cheap) fix that wouldn't require replacing the entire assy. No such luck I guess. :(
