Hard to start and won't rev
Old Feb 3, 2017 | 08:53 AM
cbr600Frider's Avatar
Default Hard to start and won't rev
Hi All,
I have a CBR600 F3 and have a problem with starting. I should say that I bought it as a non runner to give myself something to tinker with, so any problems leading up to this are unknown!
It will sometimes start if I let the starter turn to engine over for maybe 10 or 20 seconds. When it does start it sounds like it is firing on all 4 cylinders, and all 4 exhaust pipes get hot. However, it won't rev above 2000 rpm - the throttle doesn't do much when twisted from closed to fully open... the choke does make a moderate difference. I've taken the air filter off and checked that the throttle sliders are opening, which they are.
As this was a bit of an unknown to start with I've checked the cam and ignition timing, which are OK, put new spark plugs in and there seems to be a good spark. I also put fresh fuel in the tank.
I'm tempted to strip the carbs but before I do I wonder if anyone recognises the symptoms as there a a few ancillaries which I suspect could cause this?
thanks
Steve
Old Feb 3, 2017 | 09:30 AM
You're inclination of the carbs needing cleaning is probably the best place to start. The carbs on these bikes are very finicky so it's not going to hurt anything.
There are scores of threads on here to referring to carb cleaning. That should get you started and as always if you need pointers, just give a shout.
Old Feb 3, 2017 | 04:20 PM
tigertim20r1's Avatar
as above. strip the carbs, and give them a good look over.
find a manual, and make sure everything is set to standard specs, as who knows what changes have been made by others.
jkjel15
Jul 31, 2014 04:39 PM
HenryF
May 26, 2012 01:18 PM
bammerman
Sep 17, 2011 10:46 AM
Freewax
F2 Tech
Mar 5, 2011 09:37 PM
JayBoCC2
Jun 23, 2009 10:23 PM
