got some trouble, no idea what it is though
Old Dec 27, 2007 | 04:52 PM
MrGizuchuu's Avatar
Default got some trouble, no idea what it is though
the other day i got my bike out and rode it around for a min and noticed that when i got to about 6500-7000 rpm it felt like it didn't want to go any faster. didn't matter what gear i was in, and i had to give it full throttle for it to accel any faster. it still ran fine other than that, but i got it out today and it had a little trouble starting up. i finally got her to crank up and my muffler sounded completely different than normal (it was real high pitched, almost whine) then when i gave it gas it died on me. i started her back up with thechoke on and itidled at 1k rpm with choke??and every time i gave it gas it died on me. now it won't even start. when i try to, my lights go off and it makes a weird tick sound.i have no idea what the problem is. if anyone has any ideas on what might be causing pleasethis let me know.
thanks in advance for the help.
Old Dec 27, 2007 | 06:24 PM
Default RE: got some trouble, no idea what it is though
Has the bike been sitting for any extended period of time (bad gas) ? How's the charge on the battery ? How many miles do you have on it ? Has it had any recent maintenance performed on it ?
Old Dec 28, 2007 | 11:02 AM
MrGizuchuu's Avatar
well I didn't ride it for about a week bc we were moving, but i got it out 3 days ago and it ran. not too good though, thats when i noticed the trouble with the rpm and accel. the battery seems fine, when i turn my key to ON allmy electronics and lights work great. just when i crank itis when everything goes dim. my lights actually cut off while i try to crank it. no i haven't had a chance to take it to be serviced, but i bought the bike only 6 months ago and he said it had been serviced 3 months prior to me buyin it. it has 36k miles on it. could i service it myself? i'm not too sure how to do that.
Old Dec 28, 2007 | 11:49 PM
89cane's Avatar
mine had the same problem with the tick when i tried to start it all i did was clean the battery termals and all of the elctrical connections between the battery and the starter moter now it works good hope this helps
Old Dec 31, 2007 | 01:41 PM
denlimack's Avatar
I would check a couple of things... definitely the battery and terminal connections as to the clicking. As for it starting it could be the carbs but if it was running really stong before sitting a few days they shouldn't have gummed up already...
Something makes me wonder tho...the part about the whining in the muffler. This may sound weird but I would have a quick peek for mouse nests. Likely you have scared the mice out but it could still be blocked up. Wouldn't be the first time a mouse has used an exhaust can to build a nest...
Dennis
XHayabusa
Mar 14, 2011 02:11 AM
WildWill
Mar 21, 2009 10:10 AM
Orangebutter
Oct 9, 2008 10:16 AM
06cbr600rrguy
Jun 20, 2007 01:50 PM
cjbettis
Dec 11, 2005 05:22 AM
