Go fast goodies
forget the adjustable, just get a factorypro +4 degrees. huge midrange pick-up. then i'd tune your carbs for a little bit more high end power. make sure you have a k&n too.
when you're doin the sprockets, get a 520 kit. no need for the big bulky 530 chain.
just search for 'em on ebay. thats where i got mine
The only time you get a K&N filter is if you have serious head work done.If you have a stock motor,you lose power.The air intakes on these bikes and a few others are very sensitive.Use paper flters,your motor will thank you by lasting much longer also.
Revving it high won't hurt the motor,providing the bike is in gear and moving,you take care of you motor like you are supposed to and keep the front wheel on the ground.
That sprocket sh*t is for idiots.You wanna be a fast rider? Put in the seat time.The speed will come to you.You want roll-on power,go get a faster & lighter bike.
Engine work will cost you.Cost you LOTS.I have a 106hp F3 (pump gas,paper filter) and the work was very expensive.And it does not have a knife-edge/polished crank.
Spend your money on tires,learning to ride.This you can take with you wherever you go.
