fuel pump problem....
Old Oct 22, 2007 | 12:31 AM
bikereaper999's Avatar
Default fuel pump problem....
hi, i juss put my 98 cbr 6 back together after jetting the carbs n stuff... and when i put the fuel pump on, it worked fine, then i disconnected the hoses from it to take off the tank and know it runs very rapidly.... is there a certain way to hook up a fuel pump that i dont know about? please help, i need to ride.... lol
Old Oct 22, 2007 | 07:28 AM
kjohnson's Avatar
Default RE: fuel pump problem....
You turn the key off before you disconnect the pump? You're not being clear about what's happening here.Calm down.
Old Oct 22, 2007 | 08:37 AM
yes the key was off... but when i started the bike back up the pump was running bout 30 times faster than it usually did... and its a brand new pump. is there a posibility of air in the lines or what?
Old Oct 22, 2007 | 11:45 AM
kjohnson's Avatar
What do you mean by "30 times faster" ? You mean it vibrates like a cell phone when the ringer is turned off,making a buzzing sound?
Old Oct 22, 2007 | 04:42 PM
yes, exactly like that.... where as normal operation, it will kik every now n then depending on when it needs fuel....
Old Oct 22, 2007 | 05:34 PM
mycat8urskidoo's Avatar
is your tank still off the bike? if its not getting a constant supply of fuel it will vibrate like that
Old Oct 22, 2007 | 06:01 PM
yes ,the tank is on it, everything is on the bike and bolted down.... it gets fuel, cus i took the outlet line off and it sprayed fuel a couple of feet, lol....
Old Oct 22, 2007 | 07:17 PM
kjohnson's Avatar
When the bike runs for a little while,the "buzzing" will stop.All it's doing is priming itself.
Old Oct 22, 2007 | 11:36 PM
i rode for about a half hour today, it runs ok, but stutters on takeoff.... and the fuel pump , still runnin like a ****.... ? im stummped.
Old Oct 23, 2007 | 07:06 AM
marc0011's Avatar
Maybe the fuel filter is old/plugged? It might not hurt to check the flow coming out of the tank. If everything is working fine, I would check the flow from the pump a little closer. You could possibly have a bad pump outa the box.
Disconnect the output fuel line and hook up another line that runs into a container that can measure fluid levels. Next, disconnect the fuel cut-off relay connector and bridge the black and black/blue wires with something like a paper clip (little black box located on right side in front ofCDI or really big black box). Turn on the ignition for 5 seconds and then turn the ignition off. Multiply the amount in the container by 12 to derive the flow capacity. The capacity should be 700 cc (23.7 oz) min./minute. You could also just run it for 60 seconds and not use a multiplier if your container is large enough. Hopefully this tells you what is going on with the pump.
