Fuel pouring out of intake & tubes
I made the mistake of letting my bike sit a good 4 months and now when it starts, fuel literally POURS out of the ram air intake and all the hoses connected to the little air solenoid. I swapped the solenoid out with another and still have the problem. Maybe both are bad?
Opinions?
Never had this happen before. Usually after a good sitting, it just leaks some around the carbs until the seals expand again.
Thanks in advance!
Opinions?
Thanks in advance!
Was just thinking about that and I'm sure you're correct but it made me wonder - what turns the fuel pump off? Does it have a "blow by" mechanism so if there's a failure it doesn't keep forcing fuel past the valves? I don't suppose it would take huge pressure to overcome the float valves?
You'd actually be surprised at how much pressure it would take to force open the float valves. Given the size of the opening for the fuel inlet at the float valve is about 1/8" in diameter, that's not much surface area to push on. The floats have a pretty good mechanical leverage against that valve. It probably seals pretty tightly when it has to. Funny though that a grain of sand can hold it open if it gets wedged in there.
JHouse
05-07-2011 12:01 AM
