front fork oil levels??????
RE: front fork oil levels??????
Not too big a deal....take the upper tripple clamp off, right under it is two spanner nuts with a lock-tab washer between them...bend the tabs away from the upper spanner nut, and loosen it slightly (using a hammer and a punch)...then tighten the one below it....not too tight mind you....light tapping with the hammer will suffice....then retighten the lock nut on top, align locking tabs, bend them back up, put the upper clamp back on.
Yes, a shop will charge you a fortune....maybe 2 hours....BS. do it yourself in 45 minutes.
