Carb Air Cut Valve issues
Old 01-29-2018, 09:38 PM
600trike's Avatar
Default Carb Air Cut Valve issues
I built a Mid Engined Trike based on a Donor 98 F3 engine that I found never starts in cold weather, but runs great when hot.
I have to use Starter Fluid to get it started along with draping a cloth over the air intake to keep it going until it warms up.
Choke which appears to but working from the outside...has little effect
Pulled the carbs to rebuild and noticed the outside Air Cut Valve hose was broken off the valve.
My research shows that the Air Cut Valves purpose is to eliminate backfiring on deceleration I found no information on it having any part of the start cycle.
My question is...can this broken hose cause hard start when cold?
I ordered a new Air Cut Valve but won't be here for a few days.
Then Carbs go back together.
Any ideas???
Thanks in advance
Old 01-30-2018, 01:49 AM
CaBaRet's Avatar
Sounds like its running really lean, have you still got the Direct Air Induction system on,don't think you'll need that
Old 01-31-2018, 11:32 AM
600trike's Avatar
The air induction system is half there, everything that screws down to the top of the carburetors is there but the two small rubber elbows and the top section that normally sits in the front of the motorcycle is not there due to space restrictions. But I have always wondered if that might be the issue that it is running too lean because of the larger amount of air that’s being induced. Thinking that is why I have to put a cloth over the two circular intake ports on the air box to reduce the amount of air. That seems to keep it going until warms up.
but returning to the larger question, would the broken rubber hose that is connected to the air cut valve being open to the air and not connected cause the starting issue?
Old 01-31-2018, 11:37 AM
600trike's Avatar
here are 2pics Shows what parts of the air induction system are on the engine
Old 02-01-2018, 01:01 AM
CaBaRet's Avatar
Here is a basic explanation of what the cut off valve does, as long as its intact no problem, you can even block it off but you may get popping on deacceleration
https://thumpertalk.com/forums/topic...toff-valve-do/
As regards the DAI here's a mod that gets rid of the air solenoid
And
http://www.motorcycleproject.com/tex...alve_more.html
Could be the air isn't pressurising the float bowls with the solenoid in the way
File Type: pdf
Old 02-06-2018, 06:56 PM
600trike's Avatar
Thanks for all the replies. I have all 4 carbs off the bike, torn down and apart. I found nothing obvious to cause except the Air Cut valve hose was broken off. Gave them a good "ultrasonic" cleaning. I will post after I re-install and sync them.
again...thanks
redmason89
09-25-2011 10:42 PM
P_Glasovatz
05-07-2010 09:28 PM
1000rrnewb
04-09-2008 03:45 PM
techdog
12-03-2005 10:39 AM
Quick Reply: Carb Air Cut Valve issues
