Finally finished - '95 600F3
3 Attachment(s)
Well after sitting in the garage for over 6 months my '95 F3 is finally back on the road. It went from a lowered, stretched, beat up hunk of junk, to a revived, sexy chick magnet. Take a look. Not bad for a 18 year old bike, huh?
Attachment 22408 Attachment 22409 Attachment 22410 |
Looks good.
are those stock front rotors?
Well done mate! It's a pleasure to see how much actual our bikes can be in 2013! :icon_bike:
Looks brand new... well done!!
Devastating! Nice work!
Why the F2 front end?
when he said it was a modified hunk of junk when he started i assume it was like mine and was frankenstiened together. Mine was a 94 F2 that was turned into a 95 F3 exept for the front wheel looks like that may have been what happened here. You really do need to change this though if your bike is like mine and has the F3 forks you are not using all of you braking power as the F3's calipers set a little higher on the fork to compensate for the larger rotors on the F3. So change that wheel & rotors (if you do have the F3 Forks anyway) you can tell this by looking at the brake pad if it looks like there is about 8mm-10mm of the pad not bienging used or hitting the rotor you have the F3 forks and should really change the wheel and rotors.
the fact that you have the F3 fender mounted tells me you have the F3 Forks as the F2 fender will not mount to the F3 Fork. im going through this same process right now dont feel alone :(
here is a link to the parts you need, you will need #4,5,6,13,14,11 to complete the change over along with the F3 wheel and Brake rotors http://www.ronayers.com/FRONT-WHEEL-...6-C207751.aspx |
Originally Posted by ambeos5
(Post 1249733)
here is a link to the parts you need, you will need #4,5,6,13,14,11 to complete the change over along with the F3 wheel and Brake rotors FRONT WHEEL - F3 - 95-96 |
