final drive and gear box oil?
Old Dec 14, 2006 | 04:59 PM
cbr714's Avatar
Default final drive and gear box oil?
Hi guys, do we need to change these oil for CBR F3? Final drive oil and gear box oil? Thanks
Old Dec 14, 2006 | 05:24 PM
abadfish's Avatar
Default RE: final drive and gear box oil?
Yes, but its very tricky. You'll have to remove the muffler bearings and repack them upon re-installation. The gear box screws have reverse threaded torx bits of a metric size that is very difficult to get in this country. But you should be able to find that tool for a mere $200 or so (that's why the dealers charge so much for this service). But while you're at it, you may as well change your headlight fluid. Good luck!
Old Dec 14, 2006 | 05:31 PM
abadfish's Avatar
okay, I was only kidding with the previous post.
The final drive is simply our chain. Just clean it and lube it every 500 miles.
The gear box uses the same oil as your engine. So that gets done when you do your routine oil change.
Old Dec 14, 2006 | 06:24 PM
Tahoe SC's Avatar
abad...as the moderator for this section i would greatly appreciate it if you do not forget about the honking fluid next time. muahahahah...
don't sweat it 714...gotta give you a hard time cause it's fun! we all do our time...hahahaha
Old Dec 25, 2006 | 04:51 AM
cbr714's Avatar
OH, u guys scared the sh*t out of me? That was what I thought too after I have posted the threat. The final drive is the fancy term for the front smaller sprocket, that it. THanks guys.
Old Dec 25, 2006 | 04:36 PM
KidCr3nshaw's Avatar
Nah, the final drive is the fancy word for the method of power transfer to the rear wheel...
The chain.
Honking fluid...
Now for something more serious... you MUST adjust your wheelie lever, 2 or 3 clicks past Delta is a safe starting point. Good luck!
EricOh
Feb 10, 2012 03:51 AM
CBR1988
Jun 11, 2011 05:09 AM
NYKnick1015
Jun 21, 2009 03:18 PM
rgs
May 15, 2008 11:25 PM
regener8ed
Jun 11, 2006 02:25 AM
