F4i clocks on F3
Old 01-16-2019, 01:37 PM
PaulM's Avatar
Default F4i clocks on F3
Looking to put the F4i clocks onto my F3, is it just the speedohealer and the thermostat senser that is needed.
Cheers Paul
Old 01-17-2019, 07:04 AM
sjona2011's Avatar
When I did mine, I didn't bother with a speedo healer. The speed it read was within 5% of actual speed. But a temp sensor is definitely needed. I believe one from a 97-98 900rr is what you'll need
Old 01-21-2019, 12:56 PM
PaulM's Avatar
Got the clocks, going through all the wires I noticed I have a White & Red wire,I've not read anywhere of a White & Red wire, anybody
know what this is for. Looked at the wiring diagram for the f4i and it's not there for the clocks, anyone have any ideas.
Cheers Paul
Old 01-23-2019, 06:23 AM
gamekiller7's Avatar
I've got my bike torn down at ATM and if you haven't got the answer before I get home I'll check for ya.
Old 01-23-2019, 06:36 AM
PaulM's Avatar
Thanks, been told it's for the Immobiliser.It does not connect to anything, so I will blank it of.
Old 01-23-2019, 08:22 AM
Perfect, it was gonna be awhile till I got home today, rough roads here in Michigan today. The f4i gauge cluster is a really great improvement on our bikes tho .
Old 01-23-2019, 04:36 PM
PaulM's Avatar
100% better looking, just making some brackets to hold them onto the original clocks mounting points
Old 01-23-2019, 05:42 PM
Looks good! I did an RR body swap on mine and took some cardboard and fit it to my opening and then took abs plastic, copied the cardboard and that's what I mounted my speedo to
Old 01-27-2019, 07:58 AM
PaulM's Avatar
Everything is connected and works, zip tied my phone to the clocks and used the speed app and the clocks were showing the same speed as the speed app.
so hopefully I don't need the speedo healer.I will buy the Fireblade 98-99 thermostat.
Old 01-28-2019, 06:55 PM
Looks good congrats. I still haven't done my temp semsen yet maybe I'll order that Friday
Quick Reply: F4i clocks on F3
