F3 wnt starT after high speed
Old Jul 15, 2010 | 01:20 PM
  #21
cbrf3monkey's Avatar
By pass the fuel pump and see if it'll start.
Old Jul 15, 2010 | 01:23 PM
  #22
It sounds like both of you aren't getting fuel so it's either a pinch line or pump went bad. By pass it and if it runs you know that's the problem. If it doesn't solve it then I'm not sure, i'll learn something when someone else chimes in with a solution.
Old Jul 15, 2010 | 01:26 PM
  #23
nuttynu's Avatar
January 2012 AND 2013 Ride of the Month
ok, but how do u or suppose to bypass it ? thanks
Old Jul 15, 2010 | 01:58 PM
  #24
Run a line from the gas tank to the carbs.
http://www.cmsnl.com/honda-cbr600f3-...ist/F++14.html
on that diagram plug line 9 into where line 8 would be at on line 4.
Old Jul 15, 2010 | 02:01 PM
  #25
Pretty much your not plugging the fuel pump in, gravity feeding your gas into the carbs. If it starts you know the fuel pump is messed up and you either A.) need new contacts B.) its faulty. I read somewhere on here you can ride it without the fuel pump but it effects performance or something like that.
Old Jul 15, 2010 | 02:14 PM
  #26
nuttynu's Avatar
okay so the hose that connects from the tank, instead of connecting that to the pump run it to that other fuel line that is connected to thde pump???
Old Jul 15, 2010 | 02:28 PM
  #27
you have a pump and fuel filter...unplugged the one that is connected to the pump from the carb, plug that into the fuel filter connected to the tank...
Old Jul 15, 2010 | 04:06 PM
  #28
nuttynu's Avatar
alirhgt thanks cbrmonkey.. i have now figure out. its the fuel pump contacts. blown out. i've bypass the pump, and hitted the stater and it fire right back up. now i will have to wait till my fuel contacts arrive...ughhh (impatient)
Old Jul 15, 2010 | 04:11 PM
  #29
no prob. glad i can help
Old Jul 19, 2010 | 05:44 PM
  #30
nuttynu's Avatar
so today i put on the new contacts, adn the bike seems to not run. everytime i give it gas it would die.. solution ??
Piranha
Apr 5, 2013 02:23 PM
dagg92
F2 Tech
Aug 20, 2012 12:35 PM
camoweasel
May 3, 2008 03:00 PM
Coopz
Nov 15, 2007 03:55 AM
jchavers_2000
Apr 10, 2007 04:24 PM
