f3 suddenly wont turnover
Bike was running fine rode it to work today no problems. Got off from work this mourning and went to start the bike nothing just a clicking sound like the starter is kicking out but the motor isn't turning. So I tried to roll it and start it , but when I did that the tires wouldn't roll. I'm lost the bike has been running fine the only thing different is I just put on new led blinkers 4 days ago . Any suggestion would be greatly appreciated.
Not sure without more information. Things to do or check. Put the bike in neutral, check the fuses, if it turns and won't start check the spark plugs, my bike's plugs get fouled pretty easy. Do you hear the fuel pump when you key is in the on position? There are a bunch of other reason it could not be starting though.
The plugs are good and I always start it in neutral , the bike just wont turn over . When I turn on the ignition the lights come on but when I hit the ignition button you her a click like the starter is kicking out to turn the motor over but it just can't. But thanks for your help. Also it is a 95 f3
Thanks will try it in the mourning , I mean in the afternoon when I get up because I just got off of work. But what got me bothered is shouldn't I still be able to roll start it if it was the battery? Because I tried to rolled start it and the tire wouldn't roll like something was seized up.
It sounds like you might have what's referred to as a hydro-lock. What can happen is if one of your floats in a carburetor sticks open, then that allows fuel to flow freely into the carb, overfilling it. Over time, like while you're at work, the fuel flows down into the cylinder and fills it. As we all know, liquids can't be compressed so your engine won't turn over. Try removing the spark plugs, then try turning it over. If this was the issue, one of the cylinders will spray a lot of fuel out on the initial push of the starter. If it turns over, put the plugs back in and see if it starts then.
mmburns
10-21-2010 04:53 PM
