F3 Rear Shock Lifespan
I've got 38K miles on my '97 F3 now. The bike doesn't feel as tight as it used to in the corners and doesn't quite hold a straight line like it used to. I also noticed today that it was a bit more 'bouncy' in the corners. I think it's the rear shock going out.
What do you guys think the life expectancy for the rear shock should be? Is there an easy fix for the stock shock (recharge, etc)?
RE: F3 Rear Shock Lifespan
I asked about the rear shick here once...
All I got was a link to another forum. I didn't read it as all I asked was simply if it was something that can be done by the home mechanic.
Forks, from what I hear, are fairly straightforward. You just have to take your time and do it right the first time or you'll be doing it all over. I'll let you know the specifics after this weekend, I'm replacing the seals so I can finally install my new Brembo SS black, powder-coated brake lines!
Woot!
Woot!
ORIGINAL: LlanoSV
how much does a service usually cost?
Or is it cheaper to do it ourselves?
They were $140 for the fronts. The rear was $69. They are made for the 2003-2006 600RR so we'll see what happens. My buddy at the shop is confident that it'll come out good.
I'mraplacing fork oil as well... prolly isn't even any oil left in the forks, to be honest. Sucks.
on
1 Post
How longs a piece of string?. Life of shocks depends on how they have been treated, wot sort of roads & wot sort of weight they have had to carry. I would be looking at your swing arm bearings as well, same symptoms you describe if their really worn. put it on its stand and check the side ways movement.
swisherred
04-12-2009 05:05 PM
