F3 Problems
Old Jun 25, 2011 | 01:05 PM
honda23's Avatar
Default F3 Problems
So I bought a 95 F3 a couple months ago and have enjoyed it for 1500 miles till now. I was cruising with some people and all of a sudden the bike died and I coasted till it stopped. Tried cranking it over and it would spit and sputter but wouldn't fire. Sat there and made some phone calls and it started right up and i rode a few miles and it started to spit and sputter and died. Let it sit started right up and made it home running normal. It was fine for a few days then it did it again and i tried restarting it and the battery died from me cranking it over. So i put it on the battery charger the next day and it started and i had it idling and it died. Got it to run and it would spit and sputter over 3 grand. It died but it would restart but when you'd let the clutch out it'd die. Let it sit, started it again and it ran normal so i just put it away. Any ideas what it could be? I'm new to bikes so i really don't have a clue or anyone to help without spending more then what the bikes worth at a dealer.
Old Jun 26, 2011 | 08:45 PM
jveach's Avatar
does it smoke black and bog down before it die's? If it does then you could have a float bowl sticking, flooding it out and when it sits and clears all the gas it starts up. If not then I would most likely start at the fuel pump, looking for problems...
Old Jun 27, 2011 | 12:08 AM
marc0011's Avatar
Bypass the fuel pump and see what happens. My bike was having similar issues and finally it just crapped out. I bypassed the fuel pump was able to limp home. Grant the performance was effected, but it was better than a tow. If the problem goes away, look into the fuel pump rebuild.
Old Jun 28, 2011 | 12:24 PM
honda23's Avatar
no it doesn't smoke but it acts like it runs out of gas. I am experiencing some pressure in the tank from time to time which leads me to vapor lock possibly the breather is clogged?
m21oliver
Oct 1, 2018 10:52 AM
clintthec
Jul 27, 2011 06:04 PM
oldschoolsdime92
Oct 27, 2008 12:18 AM
cr cbr
Nov 28, 2006 04:36 PM
