F3 not running
Bought this 1995 cbr600 with 26000 miles less than a month ago and it ran great. I was able to rip it up and down the street no problem. About two weeks ago I was riding it and after I shifted into 2nd and give it more throttle it started to cough spit and backfire at around 8000 rpm. I got it back to my house and started to work on it, first I did spark plugs, no help. Next I put seafoam through the carbs, no help. I should mention that it idled just fine and could rev up to 12000 rpm no problem when parked and in neutral. I read some forums and someone mentioned ignition coils so I did that. Also cleaned and oiled my air filter, not sure if I did it right cause I've never done it before. Now it barely runs and it only runs if I keep the throttle on and at about 1500 rpm and it sounds like it's running on 3 cylinders. I checked the plug boots and wires and they're on there good and tight. My idea is that now it's running lean or one cylinder isnt firing. I really want to fix it myself and fix it quick cause I'm a college student and I dont want to let it sit while its non running so please any ideas welcome
here's a link to my PDF's for this bike.
https://www.dropbox.com/sh/h1a6fqjln...FWGpQqw6a?dl=0
open the one labeled "CBR 600 F3 manual" jump to chapter 16, page 312 i think it was, it has what the resistance should be of the cable's, plugs, and coils should be, that is where i would begin.
