f3 ignition problems
Old Apr 1, 2009 | 08:49 PM
hazmattf3's Avatar
Default f3 ignition problems
i have a 98 f3
i just got a new fuel pump last one was shot
fuel filter works good no blockage
fuel flow is good
it seemes to be that the plugs are getting fowled when ever i try to start it
gas spools up in the exaust and back fires
and the plugs are new
i think it might have somethin to do with the carbs
your thoughts would be appreciated
whats going on
thanks .
Old Apr 1, 2009 | 09:00 PM
pacemaker's Avatar
Saw you post in General tech so I will cut & paste it here:
(What condition is the battery in? make sure its at peak charge. Just a thought also, but you don't have the kill switch on do you? On my bike, starting from a cold motor, full choke, petrol turned off & I don't touch the throttle. If the motor's flooded, then turning the petrol on isn't going to help.
When you try to start a flooded motor, you hold the throttle open & keep it there, you don't pump the throttle. They can be sensitive buggers to start & I have seen a lot of people (not just on CBR's) put the keys in the ignition, twist the throttle a couple of times & then hit the starter, Ok if the bike is a 66 model Norton, but on modern bikes with carb's it often floods the motor (& on fuel injected bikes a waste of time)
Have you done anything to the carb's that would cause it to flood?
Old Apr 1, 2009 | 09:03 PM
hazmattf3's Avatar
havent played with the carbs at all
and before we did have it started before it needed a new fuel pump it did run rough but i think that was just due to the lack of fuel reaching the plugs
Old Apr 1, 2009 | 09:04 PM
hazmattf3's Avatar
the battery is always fresh charge the switch is at run
and it doesn't start flooded
i have the choke open and i dont throttle it at all so beats me
brap262
Mar 15, 2013 03:03 PM
Legacy
Sep 17, 2010 06:56 AM
nickp123
Aug 20, 2010 08:23 PM
ajlouni
Jun 14, 2009 05:16 PM
13oyxk
Aug 25, 2004 11:10 PM
